92 3000gt won't start
Old Mar 12, 2005 | 03:16 AM
cashsaudio's Avatar
Default 92 3000gt won't start
Hi im helping out a friend of mine that doesn't know about fixing cars but im not too fimilair with these car but its a 92 3000gt 24valves non turbo. okay it turns over but check for sparks Nothing, all 6 of do that. it has one of those 3 coil packs. What could make this do that. He said it just died when he stop at a stop sign. Thanks Jeff
Old Mar 14, 2005 | 04:02 PM
StealthR/T's Avatar
Default RE: 92 3000gt won't start
i just fixed mine, it had the same problem, it was turning over but there was no spark, check the ecu, thats what was wrong with mine. it sounds like exactly the same problem, let me know how you make out with it.
Old Mar 21, 2005 | 12:17 PM
Dylanwoods's Avatar
could be Alot of things, like the ECU as stated by StealthR/T, could be the coil bad wiring or somthing as simple as a fuse. just one of those things your gonna have to Trace out.
Old May 12, 2005 | 09:39 PM
jvskate4's Avatar
I just got a 92 vr-4 mine does the same thing. It idles out...at stop lights or signs, doesn't always do it, but sometimes. It's pretty consistent in starting up though, there are times when i have problems. But my friend and i checked the ecu yesterday and it was normal. So i don't know....if you find the solution lemme know.
Old Jun 26, 2005 | 12:46 PM
jtp94gt's Avatar
Just starting to have the same problem, mechanic said its the starter, replaced that still having the problem. Disconnect is the way to go? Also, headlights sometimes dont go,(but do pop up on my 94 gt) any suggestions?
Old Jul 2, 2005 | 03:17 PM
m3kgt_99's Avatar
I don't know if the car is still broke or not... but if it is, you can check the battery fuse. This fuse is rated at 40 amps and it is located under your hood on the left side in the box with all the other ones. This EXACT same thing happened to me and the break in the filament in the fuse was so small, that when I looked at it, it seemed fine. I teseted it and it was bad. replace that and the car should start.
Old Jul 18, 2005 | 12:45 AM
JDMVR43000's Avatar
Check Distributor
mysticrythms
Mar 19, 2014 08:17 PM
iceman33
Dec 10, 2007 12:17 PM
krkoskej
Jul 27, 2006 07:16 PM
choyneth
Dec 15, 2005 08:06 PM
samboni
Dec 15, 2004 09:35 PM
