92 3000gtsl heat does not worki
Old Dec 14, 2014 | 02:26 PM
tshirtjoe's Avatar
Default 92 3000gtsl heat does not worki
I am at wits end. I have digital automatic heat/ac The display does not work
modes work fan blows but not hot. Put in new thermostat heater lines hooked up ??? Any help would be appreciated
Old Jan 8, 2015 | 10:59 AM
toddrs93's Avatar
sounds like two different issues, the displays are known to go out, there are internal capacitors that leak and damage the display, so that will need replaced.
as for no heat, maybe the system needs to be bled out more if there is an air pocket trapped, or there is a flow issue, like a blockage in the radiator or heater core. Feel the upper and lower radiator hoses to see if they are the same temp, as well as the heater core lines
Old Jan 27, 2015 | 04:37 PM
tshirtjoe's Avatar
Found the issue. Heater core blocked. When car hot and I first turned on the heat
it was hot for a few seconds Made me think. I removed both hoses and put a test hose on the top line of the heater core an blew into it. No way Hit it with compressor air and all sorts of shi......came out the other end. When it gets hot out I will do it again and flush the system Thanks for the help
Old Jan 31, 2015 | 08:09 AM
2001Mitch3.5XS's Avatar
You want to flush through both sides of the core many times to clean it out. Not just one side...
tshirtjoe
Jan 14, 2015 08:34 AM
Robert Poteete
Dec 27, 2013 02:07 PM
n0c7
Mar 15, 2009 03:36 PM
Camel3g GT
Nov 30, 2006 06:52 PM
