Belts?
Old Oct 18, 2007 | 04:53 PM
GReddyGST's Avatar
Default Belts?
Every time I would turn on my A/C or heat, and i would give the car gas it would make this terribly loud screeching sound like a belt. I had a bunch of the belts replaced and it still does the same thing. What could be causing this loud scrreching sound?
Old Oct 18, 2007 | 11:05 PM
underpressure2003's Avatar
Default RE: Belts?
Well it can be the pullies or nees oil bro check the oil in the ac compressor or check if ur pullies are shaking a lil I had the same problem easy cheap fix
Old Oct 19, 2007 | 07:36 AM
thestealth's Avatar
Default RE: Belts?
For whatever reason, I've found these belts to be fairly finicky when getting them tightened just right. Chances are, they simply need a small adjustment.
Old Oct 19, 2007 | 07:44 PM
starbucker42's Avatar
Default RE: Belts?
I had the same problem. Mine was the pulleys. The stock pulley has a rubber piece to help with pressure from the engine if you understand what i am saying and mine orginal pulley with the rubber compltely woreout and the outside metal piece would spinb at a different rate the engine was spinning i had to get a new pulley
mr2masta
Apr 2, 2006 11:49 AM
letsstophere
Feb 12, 2006 11:47 PM
00GalantMan
Feb 6, 2006 01:31 AM
g9s5t
Aug 21, 2005 07:04 PM
mesaboogie18
Oct 8, 2004 09:51 PM
