Cooling Fans Upgrades
Old Jun 30, 2012 | 08:04 AM
BlackKat52's Avatar
Default Cooling Fans Upgrades
Has any one upgrades their factory cooling fans to work like the factory fans? If so I would like to know how you did it? Thank you
Old Jul 3, 2012 | 11:38 AM
Girly VR4's Avatar
It's really not necessary at all. If you are having cooling issues, then you probably have a clogged radiator, bad water pump, bad thermostat, or a bad temp sensor.
The only time you need upgraded fans, is when you run larger housing turbos with no heat shields that require removal of the OEM radiator fan for clearance, and running an FMIC with A/C components still in tact.
Old Jul 11, 2012 | 11:23 PM
BlackKat52's Avatar
Default cooling fans upgrades
I have headers installed on the car which in turn generate a lot of heats.Sitting in traffic especially the temperature gauge hand moves well above the mid-point where the hand stays. I have change out the thermostat to a 160 degree stat. I was just asking if anyone have changed the fans out for better cooling.
Kevsie
Jan 15, 2017 05:30 PM
vinnprocassi
Jan 1, 2012 11:36 AM
totoblue
Sep 10, 2008 03:45 PM
scitron
Nov 23, 2007 06:03 PM
jdmitsu
Sep 17, 2006 06:51 PM
