Crank but won't stay running.
Old Aug 11, 2017 | 08:07 PM
Montgomery's Avatar
Default Crank but won't stay running.
Hey I drive a 93 Mitsubishi 3000gt vr4. I recently did a tune up. I replaced all 6 spark plugs and wires and a gasket under the intake manifold. While taking the intake manifold off I had to disconnect a hose going from the intake plenum to the another hose along the firewall. The hose broke, but insid the rubber hose is a plastic hose with a check valve. I have been told the proper name for the hose is the brake booster hose. That hose is discontinued. I've used a straight rubber hose and can drive but when I apply boost the engine stales. I've used a rubber hose with a check valve inside and the motor cranks but won't stay running. Any suggestion would be appreciated thanks group.
Old Sep 4, 2017 | 08:58 PM
mxmikie's Avatar
turn the check valve around
Old Sep 30, 2017 | 06:44 PM
Montgomery's Avatar
I figured it out thanks. Could you recommend any specific cold air intake?
leadman
Oct 19, 2012 09:15 PM
marcia
Jul 8, 2011 10:20 PM
hockeypuck
Jun 1, 2011 11:10 PM
Mits2001
May 3, 2011 03:00 PM
cooley
Apr 1, 2004 01:59 AM
