engine block question
Old Aug 13, 2007 | 03:46 PM
cosmicrain813's Avatar
Default engine block question
Hi I have a 93 3000gt It has been babied all of it's life and still looks about new, sadly the motor all the sudden started to make a loud nock so I now have to replace it which leads to my next question. It is the 24 valve sl model with the 5 speed. I have a 93 single over head cam motor out of a diamante which has very ungodly low miles on it, I was wondering if I used just the bottom end of this motor and swapped my dual over head cam heads ect to the block if it would work? I have no clue on if the pistons and crank are the same.
I guess my question is are the pistons and crank the same? I know the tt's are different but not sure on the others.
[IMG]local://upfiles/13809/E43E142473C140B68665AE31B1198058.jpg[/IMG]
[IMG]local://upfiles/13809/CD4E58FB883741BDB31AAF62C3E06785.jpg[/IMG]
Old Aug 13, 2007 | 04:47 PM
thestealth's Avatar
Default RE: engine block question
Short answer, no, the DOHC heads will not work on a SOHC block.
dorian7
Jan 22, 2008 06:09 PM
cosmicrain813
Aug 13, 2007 03:51 PM
ttenn
Jun 10, 2006 01:45 AM
bedbod
Oct 30, 2005 05:59 AM
Dans Talon
Oct 15, 2004 11:06 AM
