Exhaust Problems
Old Dec 6, 2005 | 03:47 PM
sushixxxxx's Avatar
Default Exhaust Problems
I have a 1992 Mitsubishi 3000GT. Whenever I start idling for too long, like at a stoplight, white/gray smoke starts gushing out of the exhaust. Once I speed up, it seems to go away. I've recently had an oil change and some sparks/wires replaced. I have also been told recently that I have an engine oil leak and that I need a new timing belt. Not sure what could be causing this. Any ideas?
Old Dec 6, 2005 | 11:41 PM
Joel_CA's Avatar
Default RE: Exhaust Problems
Based on your description, it sure sounds like valve seals to me. Are you loosing oil between oil changes?
Joel, CA
Old Dec 7, 2005 | 02:24 AM
sushixxxxx's Avatar
Yes, I am losing oil between changes. I usually need to put more oil in once every couple months, because of the leak. Do you know what repairs would be needed specifically and how much I could expect to spend on these repairs? Thanks.
jp2000
Jan 1, 2012 05:21 PM
q7suited
Aug 12, 2008 05:48 PM
anko_kun
Mar 6, 2008 08:54 AM
p4c0
Feb 22, 2007 06:36 PM
