Full throttle cut out VR-4
Old Feb 5, 2006 | 12:46 AM
jimweee's Avatar
Default Full throttle cut out VR-4
When I go full throttle from a stop it cuts out and puffs a big cloud of black smoke. Like it thinks it is overboosting or something. The car is a 1995 VR-4 that is completely stock.. Any ideas?
Old Feb 5, 2006 | 01:32 PM
NESpeed's Avatar
Default RE: Full throttle cut out VR-4
Sounds like fuel cut to me......do you have a aftermarket boost gauge?
Old Feb 5, 2006 | 01:38 PM
jimweee's Avatar
No I dont. What causes fuel cutoff?
Old Feb 6, 2006 | 02:43 PM
NESpeed's Avatar
The MAF is sensing to much air and the computer see's the injectors reaching there max duty cycle so it cuts the fuel for a slit sec to tell you, HEY YOU HAVE A PROBLEM. Most cases it caused by to much boost.
Old Feb 6, 2006 | 08:21 PM
jimweee's Avatar
What causes too much boost?
Old Feb 8, 2006 | 12:51 AM
thestealth's Avatar
Sounds like a vacuum leak. Does it start doing it around 4000rpms?
Old Feb 8, 2006 | 11:43 AM
jimweee's Avatar
ya right around there. I have looked around for any hoses off or damaged and couldnt find any. I especially inspected the wastegate hoses that go to the intake. I am starting to think i may have a bad MAF sensor which is reading too much air traveling through it and make the computer go into fuel cut off. I am going to get a real boost gauge and go from there.
Old Feb 8, 2006 | 12:18 PM
thestealth's Avatar
You have noticed that the engine is a veritable vacuum hose nightmare... It could be any of them giving you problems. Try making a pressure tester to check for leaks. Good luck.
Genosyne
Mar 29, 2007 09:07 AM
DSMEagle1
Jul 22, 2004 10:23 AM
fmart
Dec 22, 2003 02:12 PM
