how much boost?
Old Jan 11, 2007 | 12:53 AM
edswan's Avatar
Default how much boost?
i have a 96 mitsubishi vr4 and it has aftermarket turbos and blow off valve, and nothin into the motor itself.
but i was wondering how much boost can a stock motor like this take without harming anything?
Old Jan 11, 2007 | 01:00 AM
Default RE: how much boost?
The motor itself i believe can handle 25psi. However that is not the weakest part... you will need fuel mods, tuning, bigger turbos... and more
Old Jan 11, 2007 | 01:17 AM
davidmitsusrock's Avatar
you cannot run 25 psi stock...and nelson bernarde ran 35psi on his 6g72tt(935awhp run) but stock id say your safe for about 15psi. upgraded turbos though? hmmm like sebba said you cant just add boost becouse the turbos are bigger.
Old Jan 11, 2007 | 02:24 AM
You CAN run 25 psi on the stock internals
Old Jan 11, 2007 | 10:37 AM
Are you sure about this? i thought someone on us3s said you couldn't....who knows...are you talking about stock or just stock internals?
Old Jan 11, 2007 | 11:20 AM
thestealth's Avatar
Without fuel upgrades, you don't want to run more than 12-15psi.
There have been people run 25psi on stock internals, but they had all the other supporting mods and did a great job of tuning. At that level, one error in judgement you are just asking for trouble.
Old Jan 11, 2007 | 04:24 PM
I too was looking into the VR4 scene. I did my research.
There have been people running 30psi just fine too.... but i would call that risky
Old May 13, 2007 | 12:45 AM
MitsiGTO's Avatar
sebba is right if u have a good fuel set up injectors fuel pump and stuff u can run boost over 20psi on stock motor
gstTurbo2011
Sep 8, 2006 12:00 AM
thehintons06
Jul 25, 2006 10:31 AM
thehintons06
Jul 12, 2006 07:08 PM
B.e.R.a.T
May 10, 2006 02:46 PM
turbobird14
Aug 8, 2005 10:37 PM
