intermittent clutch
Old Sep 26, 2009 | 08:44 PM
mitchcommon's Avatar
Default intermittent clutch
94 sl intermittent clutch slipping, replaced clutch master, slave, flex hose. stumped.... grabs real good most of the time slips so bad at times wont move,
Old Sep 27, 2009 | 07:53 AM
dsm1990gsx's Avatar
When does it slip the most? Does it do it more after long drives? Is it the original clutch?
Old Sep 27, 2009 | 12:38 PM
Shifty92's Avatar
I feel for ya mitch.. my 92 does the same thing.. right now it's in the "will work" stage but who knows how long that will last.. winter is coming up soon.
my clutch will come and go usually every couple weeks or so.. it will be really crappy and hard to get the car to move and then 2 weeks later it will be ready to rip pavement up.. i don't get it.
Old Sep 27, 2009 | 03:46 PM
yea no pattern to it, drove atlanta to Charlotte no problems then after approx 600 miles leaves me stranded on roadside. tow it home, get in and it works fine for another 100 or so miles and does it again. cant figure it out. dont have much history on the car, none really it has 130,000 miles. no maintenance history at all, thought maybe the slave was sticking so replaced entire hydraulic sys.
Old Sep 27, 2009 | 06:37 PM
Replace the clutch.
Old Sep 27, 2009 | 08:29 PM
to the best of my knowledge when a clutch wears out it will begin to slip and progressivly get worse until it doesnt grab at all. not intermittently . i dont feel its caused by worn clutch
Old Sep 27, 2009 | 08:57 PM
I'm willing to bet your issue is in an out of round pressure plate and a glazed disc. In which the clutch is shot.
Old Sep 28, 2009 | 12:42 AM
ok, i may be able to accept your diagnosis, but would that allow the clutch to grab firm at times and slip other times then after sitting for 6 hours work perfectly
Old Sep 28, 2009 | 02:38 AM
Shifty92's Avatar
in my cars maint. history i remember seeing a slip for a replaced clutch disc and a clutch bleed and that was supposed to fix it? I doubt it was a permanent fix seeing as how my car is still messed up like mitch is describing.. at the moment my car is in the "works fine stage" and has been so for about 2 weeks.. but before that it was shot for like 3 weeks.. keep in mind i have to drive my car almost daily due to my job.
Old Sep 28, 2009 | 07:10 AM
what about the clutch dampener??? what would be the effects if bypassed???
98Montero
Jul 8, 2014 08:43 AM
stevez
Dec 23, 2012 02:11 PM
njcaus
Oct 13, 2008 02:07 PM
Big B
Dec 31, 2004 04:47 PM
brucea
Jun 25, 2003 05:24 AM
