losing wieght on a 3000gt??
Its not a whole lot, but I got a diffrent exhaust system. this one weighs 36lbs, considerably less than the stock system of close to 100lbs. Mine is a single (on an SL) and sounds awesome. I got it for $435 from Monster Performance out of NY. It doesnt look as cool as the dual exit, but it sounds incredible and cuts off close to a 10th of a second.
Driveshaft - aluminum of CF
CF hood, fenders, hatch
Aftermarket seats
AC delete
AWS delete
cruise control delete
Active aero delete, or just remove the front if you still want the spoiler
gut the trunk
aftermarket exhaust
lighter wheels
lighter tires
aluminum flywheel
lighter battery
remove the crash bars and rear tow hooks
convert to 1st gen brakes, or NA brakes
only have 1/4 tank of gas
loose some weight if your fat
Aftermarket seats
AC delete
AWS delete
gut the trunk
aftermarket exhaust
lighter wheels
lighter tires
aluminum flywheel
lighter battery
ORIGINAL: talskinyguy
Aftermarket seats
AC delete
AWS delete
gut the trunk
aftermarket exhaust
lighter wheels
lighter tires
aluminum flywheel
lighter battery
Aftermarket seats
AC delete
AWS delete
gut the trunk
aftermarket exhaust
lighter wheels
lighter tires
aluminum flywheel
lighter battery
![Big Grin](https://mitsubishiforum.com/forum/images/smilies/biggrin.gif)
If you don't mind stripping your car completely from the interior. You can just perform a full weight reduction 'procedure'. I think its take everything out of the car that you don't need to drive.
If you just want it for fun, you can sacrifice the stereo, and A/C.
