Which one?
Old Feb 11, 2007 | 12:16 PM
supercharged3kgt's Avatar
Default Which one?
Hey, If i buy a 92 VR-4 motor, should i do a swap with my 94 DOHC base, or should i just take off all the turbo parts off the 92 motor and bolt it on my 94 motor?? The motor is like 2500.
Old Feb 11, 2007 | 03:28 PM
aorozco2's Avatar
Default RE: Which one?
if you swap the partsto theN/Athe compression ratio is10:1and you will be limited on boost to prevent detonation (knock) but will have less lag.
and if you swap the motors the VR-4 you can run higher boost than with your N/A and the motor is more forgiving to a boost spike than the N/A will, and since this isa 8:1you have more room for error as far as tuning goes.
IMO. i would swap motors and sell the N/A and get some money for other supporting mods like a boostgauge, a better clutch, turbo timer, boost controller, LSD, wideband, s-afcII, Walbro 255 (or stock VR-4 pump), exhaust, etc. . .
Old Feb 16, 2007 | 04:55 PM
fcukwithmeprelude's Avatar
Aren't the rods/crank a little weaker in the NA engine as well?
3000GT_R34SPEC
Sep 17, 2006 03:32 AM
agallardo
Sep 6, 2006 05:41 PM
98MitsGSX
May 17, 2006 06:23 AM
mitsu_soon
Nov 28, 2005 05:11 PM
darkman0127
Sep 25, 2004 06:35 PM
