RADIO CODE RESET HELP
Old Apr 24, 2006 | 01:53 AM
theend's Avatar
Default RADIO CODE RESET HELP
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
Old May 3, 2006 | 03:30 PM
Silvertooth's Avatar
Default RE: RADIO CODE RESET HELP
You shouldn't have to go to a dealership. Just CALL a dealership, explain everything you just said, and they should be able to tell you what to do without actually charging you with a visit. At least, that's what they did for me.
hollywood_cal
Feb 26, 2011 04:53 PM
route507too
Apr 24, 2008 08:27 PM
Sarinawolfe
Sep 5, 2006 10:13 AM
redsonken
Jun 9, 2006 05:24 PM
Georgie Mirage
Mar 28, 2006 04:57 PM
