replacement engine
Old Sep 4, 2007 | 09:03 AM
cd's Avatar
cd
Default replacement engine
Hi i just bought a used motor and had the mechanic install it and before he even started it up the head was leaking antifeeze could someone tell me how and y this happeed. I need your help ASAP.
Old Sep 4, 2007 | 10:11 AM
Default RE: replacement engine
Where was it leaking antifreeze. Like is it just around a hose?
Old Sep 4, 2007 | 10:19 AM
cd's Avatar
cd
the mechanic said it was comming out the head and i just bought it and the company i bought it from said there was no way that it could do that. And i dont know anything about cars this is my sons car and and yes im the mom. they said they tested it. im just lost about ready to just say forget it
Old Sep 4, 2007 | 10:54 AM
underpressure2003's Avatar
sounds like the engine was cracked if its leaking from the head good luck. Should call the company where you had it installed and tell them but i know if you installed the engine its no good if you dont have the warranty and if you did they will still give you the run around. But make sure everything is hooked up right dont jump the gun check the hoses and make sure its all good and if its leaking you wated a good amount of money so good luck and hope its something minor.
Old Sep 4, 2007 | 05:00 PM
GReddyGST's Avatar
If it's leaking anti-freeze from the head it could be the head gasket or something with the intake, it doesn't necessarily mean the block is useless
toddyfresh
Nov 9, 2006 10:12 PM
jag4277
Jun 2, 2006 04:17 AM
88 short
Nov 10, 2005 03:18 PM
Shifty
Mar 20, 2005 02:20 PM
mega386
Jan 13, 2004 02:51 AM
