smoking after long idle
Old Feb 15, 2006 | 02:34 PM
jimweee's Avatar
Default smoking after long idle
When I let my car idle for awhile when I hit the gas it smokes. I suspect a seal in one of the turbos that is leaking. Any other ideas. And if so what does a turbo rebuild cost and where is the best place to have it done? And how do you tell which turbo is doing the leaking?
Old Mar 6, 2006 | 10:26 PM
bigchief2472000's Avatar
Default RE: smoking after long idle
i got a 95 non turbo and my car does the same thing. evryone tells me that it is bad valve seals. they arent real expensive but probly cost a lot on labor. check this page out 3sx performance they got a whole set of em for like 80 bucks
Old Mar 7, 2006 | 11:45 AM
thestealth's Avatar
Pull your intercooler pipes off (at the Y) and see if they are coated with oil, that will let you know if your turbos are blowing by oil.
It could either be that, your valve stem seals, or your rings are starting to wear. A compression check will rule out rings. More than likely it is the valve stem seals though.
tatnu72
Oct 26, 2011 05:19 AM
mjboehm
1st Generation
Feb 11, 2009 05:23 PM
Braunstein82
Dec 30, 2006 11:10 AM
dencomtech
Jun 26, 2004 04:36 AM
Seth
Apr 24, 2004 02:19 AM
