so i decided to get a 3KGT as a platform car..next step
ok i decided to buy a 3KGT
i know VR4 is the twin turbo model...but what about the other two?
what is the SL? is it the same as a VR4 without the twin turbos? can i swap its engine to a VR4? do i have to buy a front clip?
what about the base model?
how can i tell the diffrence between the SL and the base model? (if i dosent have the SL badge)
im sorry if these questions have already been answered but i cant find the info i was looking for.
thank you
thank you
Mitsubishi 3000GT cars (JDM GTO label)
VR4 = 6G72 DOHC Twin Turbo All Wheel Drive (1gen 300 HP 2gen 320 HP)
SL = 6G72 DOHC non turbo Front Wheel Drive (1gen 210 HP 2gen 222 HP)
Base Model (pre 1997) = 6G72 DOHC non Turbo Front Wheel Drive (same as SL engine just less goodies in car)(222 HP)
Base Model (1997-newer) = 6G72 SOHC Non Turbo Front Wheel Drive (167 HP)
Dodge Stealth (USDM market)
RT TT = 6G72 DOHC Twin Turbo All Wheel Drive (1gen 300 HP 2gen 320 HP)
RT Luxury = 6G72 DOHC non turbo Front Wheel Drive (1gen 210 HP 2gen 222 HP)
ES = 6G72 DOHC non turbo Front Wheel Drive (1gen 210 HP)
Base Model = 6G72 SOHC Non Turbo Front Wheel Drive (167 HP)
Those are some good numbers to remember and use as a guideline. Hope that helps.
yea that help alot....thanx for the help michaels_rt
so if i get a SL and swap the engine for a VR4, will it have the same specs as a regular VR4? better? worse?
you dont have to change the engine to a VR4 engine...unless you want BIG boost. You can just TT the NA engine for less money. 10:1 compression means higher HP numbers at less boost and IMMEDIATE spool time. I am making in the region of 400 HP @ 8-9 psi. Its a LOT of fun. When I get my car back from KY I will take you for a spin. If you havent bought one yet...who knows...might peak your interest.
The FWD TT has a few advantages to AWD. Its lighter, by roughly 500 lbs. Which is HUGE. The FWD tranny also has shorter gearing so you accelerate from 0-150 faster than the TT does. The FWD isnt capable of the STUPID speeds like the TT AWD is, but who REALLY goes that fast anyways.
What I am saying is, from a roll, you will WALK a TT with low boost on a FWD. I have walked several BPU VR4s as well as Mustangs, Camaros, etc etc etc. Did lose to the Viper. Beat a C5 vette. Lost to the C6 (probably the ZO6 C5 as well, havent raced it yet). OK, thats enough rambling.
Michael
Michael
ORIGINAL: ictponder
That's what I am doing to my 95 NA. Not sure which year engine to grab the TT from though.
Michael
ORIGINAL: ictponder
Any way I can convert to FMIC?
