suspension crass member bushing
Old Nov 10, 2008 | 12:33 PM
rexbd's Avatar
Default suspension crass member bushing
I have a 94 Stealth. It appears we have a squeak coming from above the front suspension cross member where the lower control arm attaches. This bushing seems to go up into the frame of the car. Any idea if this is possible and what it takes to replace something like this. I put a wrench on it and it moves more than it should.
Old Nov 10, 2008 | 12:59 PM
mitsupartsman.com's Avatar
Default RE: suspension crass member bushing
can you see which bushing it is from this pic
Old Nov 10, 2008 | 02:01 PM
rexbd's Avatar
See if this helps the noise appears to be coming from above the mounting point of the control arm that is farthest towards the rear of the car. In looking at below the car, it looks like it is in the area above the bolt labeled 32166E
Old Nov 10, 2008 | 04:24 PM
32171c is the bushing that holds the corner of the x-member and 32155C is a rubber stopper that is located above the bushing
if the stopper is worn out it will loosen the whole corner creating noise.
Old Nov 10, 2008 | 05:15 PM
rexbd's Avatar
Can thisbe replaced from below if we get the lower suspension arm out of the way?
Old Nov 10, 2008 | 05:36 PM
i think that would be the only way. the cross member would have to come down past the mounting stud.
GARYMITSU
Feb 12, 2006 02:26 PM
94LS
Jun 2, 2005 07:07 PM
bolf
Dec 7, 2004 12:33 AM
bolf
Dec 6, 2004 11:34 PM
thewilltolive
May 11, 2004 01:11 AM
