Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
99 Diamante clicking sound at start
Old Aug 17, 2008 | 05:57 PM
sara's Avatar
Default 99 Diamante clicking sound at start
Hello!,
I own a '99 MITS Diamante and it is an absolutely great car. Since last 2 weeks there is a clicking sound (tik tik) for like 30 seconds when I start the car or turn the key on to ignition position. It goes away after 30 seconds of the car starting or being in ignition position. I dont know what the problem is? Can anyone help?
Also, the tik tik sound goes away if I turn the temperature dial to above 80 degrees and then comes again when I lower it down. Please help. I have checked the battery and alternator and both seem to be fine.
Thanks,
Sara
Old Aug 17, 2008 | 06:31 PM
dsm1990gsx's Avatar
Default RE: 99 Diamante clicking sound at start
Do you know where the clicking noise is coming from? I am betting on a temperature blend door motor.
Old Aug 18, 2008 | 08:19 PM
sara's Avatar
The sound seems to be coming from behind the dashboard. Surprisingly today the sound went off but teh check engine light came on. Says cylinder 3 misfired.
Thanks,
Sara
Old Sep 25, 2008 | 06:41 PM
Diamante725's Avatar
I have the same problem with my 01 LS. It's probably because the climate control isn't working. My A/C doesn't work but that may be only my car's problem. It has to be the climate control system "air condition/heat"because it stops when you turn the heat up to the 70's & 80's
Christian1
Mar 8, 2007 03:54 AM
Blythetrynity
Sep 8, 2006 09:35 PM
Black98
Apr 9, 2005 11:07 PM
ivant6
Mar 10, 2005 06:43 AM
1rippinGT
Jun 4, 2004 04:28 PM
