Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
HELP Car will not run
Old Sep 17, 2008 | 09:21 PM
kyle7526's Avatar
Default HELP Car will not run
Hello I have a 2000 Mitsubishi Diamonte and the other day the car was going down the expressway and then it died. I towed it home. Checked Fuel pressure, Fuel Pump is ok. Checked cap and rotor, plugs and wires, I'm getting spark, fuel, compression is normal. It turns over but will not start. Does anyone have any ideas? I'm clueless as what to do next.
Old Sep 19, 2008 | 01:45 AM
rosso75's Avatar
Default RE: HELP Car will not run
When a car dies suddenly, it's usually electrical, and usually an ignition module. I'm not familiar with the ignition setup on the 2000 model, but that's where I'd start looking.
Old Sep 19, 2008 | 08:34 PM
dsm1990gsx's Avatar
ORIGINAL: rosso75
He said he had spark so you can rile out any ignition problem.
What are the compression numbers.
Old Oct 10, 2008 | 11:00 PM
jgbrules's Avatar
the timing belt could have jumped. it may have only jumped a few teeth, but can still give you spark and fuel, but not crank due to the timing is off. pull the timing covers off and check the timing marks.
tj90
Nov 25, 2009 07:22 PM
CHRISM726
Jan 27, 2009 01:47 PM
driftin2u
Oct 22, 2007 05:22 PM
Shadowplane676
Dec 23, 2005 08:37 PM
