Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Question about sensors...
Old Dec 9, 2008 | 05:58 PM
catsag818's Avatar
Default Question about sensors...
hello,
recently my 2002 diamante LS has had issues with the traction control sensor and also the ABS sensor. I looked through these forums but did not find any DIY guides or posts relating to my problem so here I am searching for some insight. How complicated is it? plug and play with new sensors? driveway project or does it need to go to a dealer? Thanks!
-C
Old Dec 9, 2008 | 06:24 PM
mitsupartsman.com's Avatar
Default RE: Question about sensors...
do you know which sensor you need?
Old Dec 9, 2008 | 06:48 PM
dsm1990gsx's Avatar
^ Thats what I was gonna say, your gonna need to scan the trac control/abs system to find out what the fault is.
Old Dec 9, 2008 | 08:25 PM
catsag818's Avatar
The dealer ran the diagnostics and indicated the L R TCL sensor as well as the R F ABS sensor trips
Old Dec 9, 2008 | 10:09 PM
you may want to test the sensors first because they're not cheap. I believe they give off an alternating current so you can use a volt meter on them and spin a wheel. also check that your tires are all the same size and inflated properly..
pc
Oct 8, 2015 03:31 PM
earpon
Jan 15, 2012 11:50 AM
gstTurbo2011
May 8, 2006 10:10 AM
dbarker
Sep 19, 2005 11:00 AM
perna00
Aug 29, 2004 09:38 PM
