Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
signal lights and hazards not working
Old Feb 24, 2015 | 01:14 PM
Raider's Avatar
Default signal lights and hazards not working
im working on my friends 2002 Mitsubishi diamante because his daughter had a run in with a ditch this winter. the front headlights were smashed and one of the turn signal bulb holders was ripped off. i got a holder at a junkyard and spliced it back on, but none of the signal light system is working. the hazard button does nothing and neither does the turn signal stalk. i've read that i should check the hazard switch and replace it if high resistance is found, but i dont know what 2 of the 9 contacts to check.
any help with this is GREATLY appreciated!
also, i cant get the trunk open to check the back turn signal, either with the door button or the key. ideas?
thanks
Old Feb 24, 2015 | 02:38 PM
Raider's Avatar
nevermind, it was a fuse under the hood for the signal lights, and the relay for the fuel door and the trunk release has corroded contacts.
2nd g eclipse gst
Jun 14, 2014 12:32 AM
Russ2123
Jun 18, 2013 03:46 AM
Jenn Olsen
Dec 29, 2011 01:35 AM
dornstar
May 22, 2006 04:58 PM
95 Montero LS
Feb 7, 2006 12:01 AM
