Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Stereo wiring
Old Aug 18, 2009 | 05:28 PM
Islandboy's Avatar
Default Stereo wiring
I need to run an 8 guage power cable from my trunk to the battery in a '99 Diamante. How should I do this? Under the car? Through the interior and through the firewall? Any help would be appreciated.
Old Aug 20, 2009 | 08:18 AM
BEAT's Avatar
You can put it on the driver side door.
Open the door. look at behind the hinges top and bottom. LOOK there should a small opening going to the trunk or engine compartment. use a hard wire as a guide with the electrical wiring attached or 8 gauge is think enough to slide
Just look for an opening. remember open the driver side door.
If not I don't recommend PUTTING A HOLE on your dash. Why?
Water will get inside using the wire that you put as a Bridge. it is like straw but the water flows on the wiring going to your dash and it might cause a short circuit.
Also check if there is a rubber patch or O ring that is on the firewall. anything that is an opening can help you.
thejones10
Sep 11, 2007 11:46 AM
mallet
Jun 16, 2007 09:19 PM
RXtreme8
Feb 9, 2007 12:51 AM
Griffeycom
Dec 24, 2006 08:27 PM
Toohey
Jun 29, 2005 04:20 AM
