Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Vent Mode Inoperative
Old Nov 21, 2013 | 11:19 PM
IN-D-RUFF's Avatar
Default Vent Mode Inoperative
Recently, the damper motor that controls vent location (Defrost, Dash, Floor) froze and became inoperative. After some research I found out that the damper motor (PN# AW339321), located behind the lower dash on the Left (Driver's) Side and mounted to the heater box was inoperative.
Then after pricing a replacement ($317.53) at the local Mitsubishi Dealer I decided to do a little more diagnostics before committing to such a ridiculous price. I removed the damper motor, pinned out the connections and saw that I had continuity, then pinned out the connector to confirm that there was power going to the motor.
I thought that maybe moisture had invaded the motor, so I tried to manually move the control arm. Then I lubricated all the joints with silicon spray and re installed the motor. I turned on the climate control to give it a signal, and the motor adjusted the vents to Defrost!
Then I ran the climate control through the cold to hot cycle then observed the vents adjusting from DEFROST to DASH to FLOOR without incident. I did it about 10 more times then reassembled the dash components.
The climate control is now working as designed. So before spending all that money on a tiny electric motor, do what I did; remove, lubricate, reinstall then test. The whole procedure took about an hour and the results were priceless.
Old Nov 22, 2013 | 04:22 PM
mxmikie's Avatar
results were priceless ???? what does that mean priceless
Old Nov 23, 2013 | 09:30 AM
IN-D-RUFF's Avatar
Default Meanings
It means that I was able to repair the HVAC and it didn't cost me any money!
niazqamar
Jan 7, 2015 11:19 AM
tojawent
Jul 11, 2007 11:56 PM
Jasn1981
May 2, 2006 06:00 PM
jrk247
Apr 2, 2005 02:48 PM
Scruit
May 13, 2004 04:48 PM
