2006 Endeavor AWD LS cylinder 2 misfire
Old Oct 17, 2021 | 04:25 PM
Mpphil31e's Avatar
Default 2006 Endeavor AWD LS cylinder 2 misfire
Got an error code P0302 (cylinder 2 misfire). Google to find common reasons. Changed all plugs, coil pack, valve cover gasket. Still had code and rough idle/misfire. Then got Crankshaft location sensor code, as well as camshaft location sensor code and Still had misfire code. Replaced both sensors. Still getting P0302. Cylinder 2 misfire. Any assistance would be greatly appreciated. I'm kind of at a loss of where to go next.
Old Oct 26, 2021 | 10:20 AM
whilst01's Avatar
Hi. Understand your frustration. You've covered basics.
What's maintenance history? T belt change?
Mileage on vehicle?
Jeff
Old Sep 5, 2023 | 01:02 PM
RH777's Avatar
I have a 2007 Endeavor LS 2WD. Mine had similar issues where it would start shaking violently while trying to accelerate. Twice, I had a coil pack replaced. Once it started doing it again, a mechanic I called told me to pull the coil pack and swap it with a coil in a different position to see if the problem followed the coil pack. I did that and the vehicle behaved normally. No violent shaking or anything. Not sure if this has happened to anyone else but that mechanic really did me a favor and didn't fleece me for cash.
jaystihl
Aug 18, 2021 06:06 PM
Diddy
Nov 15, 2016 05:05 PM
Thewoodieb
Oct 10, 2013 12:47 PM
jay964
May 2, 2013 05:57 PM
nebeeseer
Nov 16, 2008 02:57 AM
