2006 Endeavor low idle / stalls
Old Apr 23, 2017 | 08:56 PM
spencerisadog's Avatar
Default 2006 Endeavor low idle / stalls
Hello all! First, thanks for a place to come and ask questions. Second, my question:
My wife drives a 2006 Endeavor, it's completely stock. She was having problems with it starting, come to find out it was a battery terminal I replaced a few years ago corroded enough between the wire and the terminal. I replaced the battery for good measure, cleaned the terminal and now it starts like a champ. However, if I start it and let it set it begins idling very low to the point of stalling frequently. I noticed that when the fan kicks on it idles just fine, hovering around 1000 rpm. When the fan turns off it drops to probably 300 - 500 and often stalls.
Any suggestions on things to replace / check?
Thank you!!
Old Jul 25, 2018 | 06:52 PM
Todd68's Avatar
Thank you!!
im having the same issue
Old Sep 28, 2022 | 08:24 PM
joell.orme@outlook.com's Avatar
Default Having the same problem
Thank you!!
did you figure out the problem ?
Old Sep 29, 2022 | 07:55 AM
whilst01's Avatar
Default low idle / stalling
Hi. Did this just suddenly happen? How many miles on car? Service history - well maintained? Any codes thrown?
I have an '04w/180K. Similar problem 'suddenly' happened. Check engine light said P0104. Low EGR flow.
Just spent last few days R&R ing EGR valve,tubes. Cleaned thoroughly along with Throttle body. Runs great,no codes.
> While doing these, I also did my valve cover gasket and spark plug tubes w/ new plugs for rear bank.
Shouldn't have to fool with any of that stuff for awhile,if ever.
If DIY, a few hours < $100.
Stealership $$$! EGR alone is $400 ish.
HTH.
Old Oct 10, 2022 | 07:27 PM
whilst01's Avatar
Did we find out the problem / solution?
Bardcastle
Jun 18, 2019 10:37 AM
Dales427
Dec 11, 2015 03:01 PM
latchis
Aug 20, 2013 02:15 AM
bordermec
Jul 18, 2013 01:09 PM
