2006 No stereo, turn signals, interior lights since cutting trailer wire
Old Apr 30, 2021 | 05:27 PM
Sasjzl's Avatar
Nope. Stuck in a dealership. They have had the car since Tuesday and have not been able to diagnose the problem. Allegedly I am only going to have to pay for 1 hour of diagnostic work.
Typical dealership ridiculousness. I assume they are pondering the problem, at best, between working on new more expensive cars. My best guess is that there is a wiring issue upstream of the ETAC ECU. Correct me if I am wrong but the only ‘computer’ that controls those 3 functions, Interior lights, stereo, directionals, is the ETAC ecu. As previously noted I have already tried simply replacing it with a junkyard one.
I really only need to get the turn signals to work to pass inspection. Anyone know of a way to do that outside of the normal electrical system?
Old Apr 30, 2021 | 05:36 PM
whilst01's Avatar
Default wiring
> Never answered: 'aftermarket' install of trailer wiring? I couldn't find 'factory' wiring leads. ETACs' also controls security - immobilizer. Not sure what else.
Keep me/us posted. Best,Jeff
Old May 1, 2021 | 11:24 AM
Sasjzl's Avatar
Aftermarket would describe the connector between the cars wiring and the trailers wiring. It is a common trailer towing accessory that allows you to add trailer wiring. I have benn using it for years and it came with the car. Made by Curt Manufacturing.
Old May 1, 2021 | 12:06 PM
whilst01's Avatar
OK,gotcha. I've used them as well.
Looking at my online manual, everything points to ETACS. Did you compare serial & model #'s of replacement ETACs?
They did change them during production run.
Because you stated "engine runs",etc. without programming, I'm suspect of that ebay module...
I would strongly suggest you spend the $15 for an online manual.
Jeff
Old May 1, 2021 | 12:10 PM
whilst01's Avatar
Fuse # 20 - 'Hot in On or ACC'. 7.5a
Fuse # 23- 'Hot in On or Start'. 7.5a
ehsanabria
Sep 22, 2022 06:22 PM
Russ2123
Jun 18, 2013 03:46 AM
prozac12
Oct 5, 2010 03:38 PM
ehsanabria
Feb 20, 2008 08:54 AM
imapirate30
Jan 8, 2007 11:08 PM
