Just bought a 04 endeavor.
I just bought a 04 endeavor in very good condition. It has 122k miles and I want this baby to last. the car has no leaks runs perfect just needs new tires. Only bad thing is no history on anything replaced. So with these many miles what is recommended to be replace on these cars? I also cant find maintenance schedule on the web anywhere, anybody know where I can pull this up? Thanks a lot for your help.
I have replaced brakes, tires, discs, battery timing belt and tensioner , plugs, coils. O2 sensors, manifold, cats, tranny, and now I tried to reprogram key and shorted out wrong OBD2 pins causing horn to stay on blasting , rear wiper runs and squirts till empty, and parking light on till battery dies,
Can anyone help me fix this problem suppose to short pin 1 and 4 I did worng ones and horn blasted and all other things above at same time.
I was sent mail saying timing ECU , there is one under dash, one in plastic box under hood and one in fuse box a oblong snap in one piece ?
Hi
I tried each of the ECU modules all 3 and nothing changed. I replaced one relay and the horn stopped blowing and then reset ECU and have no problems now but car will not start , no crank. OBD error crank shaft sensor but I did all that 3 yrs ago. ???
Hi
I was told that my "timing" ECU is bad , can anyone tell me which one that is ?
There is one under dash at fuse box, one in fuse box under hood in a module and then there is the computer ECU at front of car near the radiator in plastic box
However, I did go to dealer with ALL my keys and remote to have them programmed-$125.....
Some locksmiths have software to do this, cheaper.?
HTH,whilst
t0adman
Nov 2, 2009 12:45 PM
