timing belt or chains?
Old 08-28-2014, 09:07 PM
Chef's Avatar
Default timing belt or chains?
to all the V6 engines have timing belts or chains? if they do have chains in what years did they use them?
thanks
fab
Old 08-29-2014, 03:10 AM
Akzle's Avatar
belts. usually. a thirty second google search would have told you this. your engine displacement and/or model number would have made it even easier.
Old 08-31-2014, 03:37 PM
Chef's Avatar
Thanks for the reply...i guess i was just making sure that it was indeed a belt, and so it is.
The car has about 62 000 miles on it, is it safe to say it can last up to the 100 000miles that mitsubishi says it should be changed at?
we will be going through winter in a few months..
thanks
fab
Old 09-01-2014, 08:27 AM
magna buff's Avatar
for any V6 mitsubishi
I do them at 90,000 just to be different and safe
if the belt breaks at anytime the pistons hit the valves
replace the tensioner bearing and check the timing cam seals for leaks
you can get a timing belt that is supposed to last 5 years but have not located a supplier
the water pump needs to be changed as well at the same time
or else it is double work when they leak or corrode
13 inch cable chains
12-18-2008 11:59 PM
morpheysrevival
11-26-2008 07:29 PM
xyzik
12-07-2007 08:58 AM
dorian7
11-12-2007 11:06 PM
wymanc
02-14-2007 12:28 AM
Quick Reply: timing belt or chains?
