Turbo upgrade
Old Dec 3, 2007 | 12:02 PM
  #21
Default RE: Turbo upgrade
ORIGINAL: Sebba
Damn mean to TE hahahaha Love it
im used to it
Old Dec 3, 2007 | 05:16 PM
  #22
ORIGINAL: TheEngineer
ORIGINAL: Sebba
im used to it
you deserve it you newb lol
Old Dec 9, 2007 | 12:24 AM
  #23
XTREME's Avatar
Okay, see the pictures below of the install.
My brothers and I were able to get the old turbo, O2 housing, and exhaust manifold off the car. We then took and replaced the cams with GSC S1's and while there installed the ARP Head studs. Next weekend I'll be installing the fuel pump, FP green turbo, injectors, and downpipe. Hopefully it will be running by the end of the day next weekend.
Emonz, a couple of questions:
1. My old exhaust manifold gasket consists of three layers of copper. Can I reuse it, it looks pretty good (maybe because I only have 10,000 mi on my car). Also, what about the other metal gaskets such as the 02 housing? Where is the best place to pick up gaskets, I need one for the oil return line on the turbo.
2. How do you get the back seat out of the Evo to install the fuel pump. Any tips on installing the fuel pump? I wasn't able to locate any decent write-ups...
3. When installing your 50 trim, did you use the stock wastegate actuator or did you upgrade. If you did upgrade, how did you know where to set your actuator on the adjuster?
Sorry, that was more than a couple questions. I may come up with more as I think about it over the week.
Old Dec 9, 2007 | 07:55 AM
  #24
The gaskets I would buy new ones. they cant cost much. and mitsu might be the place to get them
To get the back seat out there are 2 pull tabs under the lip of the seat on the front side of them they are plasitc. when you pull them the seat will pop up and then you take it out from there. the fuel pump is easy. no wiring needed you just drop in the pump and your done. Take the old on out and toss in the new one. only issue is it can be a pain in the ***** because the housing just barley fits into the tank so you have to fight it for a little bit to get it in there.
My 50trim is not internally gated. I have an external 44mm TiaL wastegate with a 15lbs spring. So yea I dont have any clue for an internally gated turbo upgraded
Old Dec 10, 2007 | 09:22 AM
  #25
Most of the gaskets that we got for mikes kit i ordered from ATP here
http://www.atpturbo.com/Merchant2/me...egory_Code=GSK
Old Dec 10, 2007 | 05:56 PM
  #26
Thats not true. I got 2 gaskets from them. the oil return and the turbo gasket for the bottom of the manifold. All the other gaskets came from mitsu. I.E. valve cover, intake , exhaust manifold, spark plugs and so on. Oh an the headgasket I used was OEM but bought from AMS
Old Dec 11, 2007 | 06:14 AM
  #27
true, i was mostly pointing him there cuz he was looking for an 02 housing gasket and the oil return gasket
Old Dec 11, 2007 | 03:56 PM
  #28
Yea for stock stuff though. Mitsu will have that as well. Why not just get them all at one place unless the price is a huge chunk of change difference
Old Dec 15, 2007 | 11:23 PM
  #29
XTREME's Avatar
All the parts have been installed but I haven't been able to start the car yet. My brother put the wrong size bolt in the O2 housing and stripped the thread. Tomorrow morning I'm going to repair the problem and then should have it running. The only other incident was stripping off one of the studs the exhaust manifold bolts on to. I was torquing them down and one gave way. Does anybody know if you have to take the head in to get this fixed? I'm going to run it like it is for now; don't think there should be any trouble as long as the other bolts are torqued down correctly.
Old Dec 15, 2007 | 11:33 PM
  #30
Bolts are fairly easy to tap out. All you need is a reverse thread bit, you drill a hole in the broken bolt, you hammber the bit into it, attach the drill, put it in reverse, and away you go.
