01 Galant engine issues
Old Dec 19, 2011 | 03:17 PM
galantenthusiast's Avatar
Default 01 Galant engine issues
Hello everyone, it's my first post on the forum. I have a 2001 mitsubishi galant, 3.0 L V6 engine, that has been having issues for some time now. I just got a coolant flush/power steering flush and the mechanic found 3 OBD codes while inspecting the car.
2 codes I already knew about, P0441 - evap system incorrect purge flow, and P0446 - vent control circuit. I believe that these were complications from when my fuel pump was replaced in the car, and some fuel got into the charcoal canister and clogged it. I tried locating the vent control valve sometime back using the Haynes repair manual, but I could not find it's location under the car. This doesn't seem to affect the drivability of the car, although after reading up on this I may not be able to pass emissions next time I go, but I'll have to deal with that then.
The new code which is troubling me is that I have a P0301 - engine cylinder 1 misfire. It makes sense because the car has been idling roughly, etc. On the V6 model, I believe cylinder 1 is one of the back cylinders that is under the upper intake manifold (can anyone confirm the cylinder layout for this engine model??), and getting back at it is a real pain (have to remove the upper intake manifold, which involves disconnecting sensors, evap system, egr system, remove power steering drivebelt, etc.) and while I have done repairs on the car before, it is a huge undertaking. And that being the case, I'm sure that taking this to a shop for diagnosis will also cost a pretty penny (last time I got my spark plugs changed it cost a couple hundred dollars because getting at the back spark plugs required all this work).
I thought about using seafoam on the engine to see if this might help the problem, but it makes me a bit nervous, plus I don't know if the brake booster vacuum line/pcv line distribute to all 6 cylinders evenly. Any advice on how to go about fixing the problem would be really appreciated. Thanks in advance!
Old Dec 22, 2011 | 05:44 PM
Galanthighspeeder's Avatar
P0301 means you have bad Fuel Injector on Cylinder 1..
you should replace the Injector if not it will damage the engine.
Old Dec 22, 2011 | 09:17 PM
_93TSI_370+K_'s Avatar
Try searching the web, it is an amazing new concept.
http://www.obd-codes.com/p0301
Theoretically the vacuum should be equal everywhere in a closed container, but if you had a vacuum hose nipple in the intake port, you would see a variation in vacuum there. The brake booster vacuum line/pcv hose...a vacuum is not "distributed" to the cylinders.
Do they put a little box on the hood of your car when you get emission checks? In which case you have to get the code fixed, but if they check for a CEL..????
Joeyp2100
Jul 10, 2005 04:48 PM
b_bruton77
Jun 30, 2004 12:20 AM
b_bruton77
Jun 23, 2004 10:04 AM
b_bruton77
Jun 19, 2004 03:28 PM
DarkrealmX
Feb 15, 2004 07:47 AM
