03 Galant Heater is blowing cold air
Old Jan 27, 2010 | 01:44 PM
spicy7up's Avatar
Default 03 Galant Heater is blowing cold air
Hi,
I have a 03 Galant ES with 107000 miles on it. My car is running fine. Yesterday my heater was working fine, but due to warm weather i change it to AC for few minutes. Today Morning when i start my car and turn the heater on, it's blowing cold air only. I check my coolant level and it's below the low mark on it.
Any help/suggestion on this. What could be the problem? I am planning to add some coolant in it. What kind of coolant it takes for 2.4 L engine.
Any suggestion would be greatly appreciated,
Kalpesh
kalpesh_er1@yahoo.com
Old Oct 22, 2010 | 09:36 AM
bigdarkand's Avatar
I'm having similar experience with my 03 galant too (95000miles), can somebody help us out please? Thanks
Old Oct 22, 2010 | 10:09 AM
roadrunner4sp's Avatar
Originally Posted by spicy7up
Hi,
Kalpesh
You can use any coolant that is 50/50 mix all ready in the bottle.I have a 2006 galant and i use prestone 50/50 mix. It is about $8.00 gal. @ wal-mart. As for no heat. check the coolant level in the radiator when the car is cold.If it is low that mean you have a leak.Low coolant = no heat or low heat.Hope this helps.
Old Oct 22, 2010 | 10:13 AM
bigdarkand's Avatar
Thanks for the info. God bless and have a wonderful weekend
Old Oct 29, 2010 | 05:00 PM
andre110's Avatar
If your coolant level is ok, check the blend door control motor.
Old Nov 5, 2010 | 10:26 AM
bigdarkand's Avatar
I'm still having the same problem. the coolant level is ok, the cable that control the blend door is ok. The only thing that I noticed was that both heater hoses that came from the engine into the firewall are not warm talkless of being hot. Though, I check the thermostat, it seems to be working. who can give me an hint of what is going on. Thanks
Old Nov 16, 2010 | 03:59 PM
MK ultra's Avatar
It could be the heater matrix itself that is £uckd
Old Sep 16, 2011 | 11:03 PM
Brian03Galant's Avatar
if your coolant level is good.. I would check the heater shut motor or also called the air amplifier. It is located under the center of the dash behind air ducts on the heater core pipe right before it goes into the heater core. Switch the temp switch back and forth and see if the white arm is moving. If not you can only get the item from the dealer and it is around $150. This is a common problem on galants.
trtmntdude
Jun 21, 2010 09:55 AM
mhorn0817
Jan 6, 2010 06:19 PM
BokeSmowls
Jul 2, 2009 04:04 PM
p4c0
Feb 22, 2007 06:36 PM
