2001 Galant Vent issue.
Old Apr 30, 2006 | 06:14 AM
Jasn1981's Avatar
Default 2001 Galant Vent issue.
I have a 2001 Galant, and my vent doesn't seem to work right. It always blows warm air. I don't believe that it's because of the fan blowing because when I push the button to make it "re-circulate" the air it stops. Is it a outside vent being stuk open, and if so how can I check or fix it? Thanks
Old Apr 30, 2006 | 11:19 PM
Joel_CA's Avatar
Default RE: 2001 Galant Vent issue.
The fix to your problem might be the same as the one i posted for "Galant Heat"- check it out..
Good luck!
Joel, CA
Old May 2, 2006 | 04:00 AM
Jasn1981's Avatar
ORIGINAL: Joel_CA
Good luck!
Joel, CA
Thanks. I read your post, but it's not the same thing. It's like a otside air vent is stuck open or something like that. I hope someone has some idea of what it is.
Old May 2, 2006 | 05:56 PM
NYNick's Avatar
Did you trace the cable from the back of the temperature know to underneath the drivers side dash? The cable is connected to a white plastic "pulley" with gear teeth. That white pulley is connected to a small metal gear which is connected to a shaft that opens and closes the duct doors. Check to see if all of that is intact.
Old May 2, 2006 | 06:00 PM
Jasn1981's Avatar
I'll check that out. I just replaceed the Temp cable because it was binding. This problem started well before that though. I'll look at that gear later today. Now that I know where the vents are.
4Grim
Mar 6, 2008 05:20 PM
antlip
Jan 6, 2008 07:49 PM
zeanimal2001
Mar 22, 2007 01:01 AM
jrk247
Apr 2, 2005 02:48 PM
Scruit
May 13, 2004 04:48 PM
