2002 Galant GTZ V6 Coolant Leak
Old Aug 11, 2013 | 11:55 AM
KevGTZ's Avatar
Exclamation 2002 Galant GTZ V6 Coolant Leak
My 2002 galant GTZ with a V6 has been overheating and I checked all the forums. I changed the thermostat and made sure the fans were coming on when they should, which they are. I also checked the oil and it looks good.
I did notice a coolant leak back in the engine, under the thermostat housing. It does not seem to be the thermostat housing. What gasket might be leaking? Could it be the head gasket but it is leaking out instead of going into the oil?
Old Aug 11, 2013 | 12:42 PM
Akzle's Avatar
frost plug
Old Aug 11, 2013 | 12:58 PM
KevGTZ's Avatar
How much of the engine do I have to take apart to change that.
Old Aug 12, 2013 | 03:04 AM
Akzle's Avatar
drill a hole in it, screw a slide hammer in, pull it out, push the new one in and smack it with a ball peon......
so remove enough that you can manage all that.
Paul Russo
Aug 29, 2014 01:22 AM
Dave Braun
Feb 22, 2012 03:14 PM
Shane89
Jun 30, 2011 03:56 PM
ruski
Dec 30, 2010 05:32 PM
