Car will not start!
Old Sep 5, 2008 | 02:58 PM
gm12111's Avatar
Default Car will not start!
[:@]I went go gas up today and just as i was PLANNING on leaving the 01 galant had different plans. car will turn over everything sounds fine just wont start. I think it is electrical. Relays or fuse somebody help me. Thanks.
Old Sep 5, 2008 | 06:10 PM
Default RE: Car will not start!
Check all fuses.
Old Sep 5, 2008 | 07:45 PM
dsm1990gsx's Avatar
Check to see if you have spark and fuel.
Old Sep 5, 2008 | 08:43 PM
gm12111's Avatar
i think all the fuses are ok, just got done checking them. how do i check if i have spark and fuel? i replaced the fuel filter, fuel pump about a month ago.
Old Sep 5, 2008 | 08:59 PM
Hold the throttle while trying to start it, then pull a spark plug out.. and see if its wet. Wet = fuel
Spark, take a spark plug out... connect it to the spark plug wire.. .and turn the engine over while someone holds it.... look for a spark... or just hold it
Old Sep 5, 2008 | 10:31 PM
gm12111's Avatar
yerr!!! k so i took the plugs out and i have a spark. i cant smell gas so i am thinking it must be a fuel problem. any ideas?
Old Sep 6, 2008 | 05:07 PM
dsm1990gsx's Avatar
Try spaying a can of 2+2 in the intake and see if it runs for a little ,but but sounds like you havea bad fuel pump.
Old Sep 6, 2008 | 08:52 PM
Thats a great idea, spray carb cleaner into the throttle body when startng it.
arupc66
Feb 12, 2013 10:02 PM
dahoopd
Nov 4, 2010 08:10 PM
ajcoolman
Sep 24, 2006 03:49 AM
galant_girl
Sep 27, 2005 10:29 PM
chrome0011
Feb 29, 2004 11:46 PM
