car not moving after start
Old Feb 10, 2013 | 11:03 AM
arupc66's Avatar
Default car not moving after start
Dear All
I have a Mitsubishi Outlander 2008 CVT model that I purchased 6 months ago. Today, suddenly, the car is not responding to the gas pedal while the engine starts alright and is racing if I press the pedal. I have used the Diaqueen CVT fluid for transmission oil 3 months ago - as specified in the manual, so, that is not likely to be the problem. Can this happen because of fault in the front axle shaft assembly or the problem in wheel hub assembly ? Any advice appreciated.
The problem is this is an imported car and the local dealers in Cairo do not have knowledge about this car...
thanks
Old Feb 10, 2013 | 02:19 PM
milliesdad's Avatar
Sounds like you have transmission problem.
Does the car move at all when put in gear?
Imported or not, a Mitsu OUtlander is the same where ever it was built.
Old Feb 10, 2013 | 04:55 PM
ivanz's Avatar
Details? Does it change gear on the LCD? Does reverse work? Try putting it into manual shift and start in 2nd gear (not sure if the CVT has this, the 6 speed auto does).
Old Feb 10, 2013 | 11:38 PM
Burtonrider10022's Avatar
Will it go in reverse?
Can you hear it "click" when you move the shift **** or could the linkage be disconnected somehow?
Old Feb 11, 2013 | 06:41 AM
tinker's Avatar
This happened to a car I had, it was one of the drive shafts to the front wheels had sheared
Old Feb 12, 2013 | 10:02 PM
arupc66's Avatar
thank you all. I am currently travelling. Will check on my return and update.
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
jsawyer
Jun 14, 2007 12:31 AM
Mike21
Oct 10, 2006 04:36 PM
