Fuel injectors
Old Nov 11, 2005 | 11:15 PM
et2sub's Avatar
Default Fuel injectors
Does anyone know the stock injector size? Also what is recommended size, if upgrading intake manifold? or could the stock handle that much more air? One more is too lean bad for the engine?
Old Nov 12, 2005 | 10:59 AM
Lil red's Avatar
Default RE: Fuel injectors
what year/model?
Old Nov 13, 2005 | 11:18 AM
et2sub's Avatar
2003 galant es 2.4l
Old Nov 13, 2005 | 01:00 PM
Joel_CA's Avatar
The stock injectors should be able to keep up with just about any fuel demand you can give it with minor upgrades. Intake pipes, freeflowing air filter, and catback exhaust is what i consider to be minor.
Joel, CA
Old Nov 14, 2005 | 04:45 PM
et2sub's Avatar
I have already replaced all that. I am talking putting a bigger intake manifold on.
Old Nov 16, 2005 | 02:59 AM
Joel_CA's Avatar
A bigger intake manifold isn't going to get you anywhere as your engine operates on vacuum. Even at 100% volumetric effeciency, it will only suck in as much air as it displaces unless you force it in (Turbo, etc).
Joel, CA
agallardo
Feb 22, 2007 03:46 AM
dsmchick97
Nov 17, 2005 09:49 PM
Laxstar785
Apr 28, 2005 11:03 AM
osu girl
Jan 11, 2005 03:33 PM
antomx
Sep 4, 2004 07:19 PM
