Galant: Balance shaft bearing problem
Old May 13, 2010 | 02:46 PM
steveb's Avatar
Default Galant: Balance shaft bearing problem
Galant 2.0 Sports 2002.
I've got a problem on the balance shaft on which sits the oil pump. Originally there was a slooshing noise from the timing belt area, then mechanical clattering/whirring .....
The balance shaft bearing has broke off and dropped into the sump, so needs replacing. As it is hydraulically pressed into a casting, it may not be possible to replace as the casting could well be damaged, so things don't look too good.
  • Anyway, can anyone advise ?
  • Has anyone encountered this problem ?
  • If so, was the cause established ?
  • How were you able to fix it ?
Any thoughts on this would be appreciated.
Thanks,
Steve.
Dustin0330
May 3, 2015 01:10 PM
renalese
Apr 8, 2012 09:18 AM
n2daizo123
May 16, 2006 08:17 PM
93eclipsegsx
1st Generation
Mar 5, 2006 12:13 PM
EclipseGSRoadRacer
Oct 5, 2004 05:54 PM
