Galant ES, Engine Stalls at Idle, 4cyl SOHC
Old Jan 7, 2009 | 02:36 PM
yuanchueh's Avatar
Default RE: Galant ES, Engine Stalls at Idle, 4cyl SOHC
It worked...my car was dying all the time, and now it is working like a champ...thanks so much guys.
Old Apr 21, 2011 | 03:05 PM
XeoNoX's Avatar
thanks for the tips guys, i figured i would add how to clean the MAF ( Mass Airflow Sensor ) since it is right there also when u clean TB. http://www.thegalantcenter.net/showthread.php?t=30876 (pretty much a can of CRC Electoronic cleaner and a can of AIR to clean MAF)
Old Mar 27, 2020 | 07:30 PM
Gary Pennington's Avatar
Default Csps
Originally Posted by rmorse
Hello,
I have a 2000 Mitsubishi Galant ES with 4cyl, SOHC engine with 79,000 milesIt stalls while idling but only while warming up as I will describe here. It idles fine for the first couple of minutes after starting with a cold engine. Then stalls while idling for about the next 10-15 minutes. Then after a while idles fine again. Otherwise engine runs very smooth at all speeds, except stalls at idle as described above. I can keep the engine from stalling at idle by pressing gas pedal slightly to keep RPM's to just under 1,000. Also, when engine stalls it is smooth, no jerky motion from engine. It's as if someone turned off the key.
Engine always starts immediately when starter engaged (at any time).
No OBD / DTC codes set. Spark plugs and air filter replaced ~6mos ago with no problems until this week. Has integrated fuel pump filter that factory says should not need to be changed.
I live in coastal San Diego with a very mild climate. Outdoor temperatue in 70's F.
Does anyone have any ideas on diagnosing? Any suggestions would be greatly appreciated.
Robert
Crankshaft Position Sensor....I guarantee it. I went through the same thing.Make sure everything is clear about crankshaft position sensor or camshaft position sensor. Good Luck...
Shadowplane676
Jul 7, 2021 07:50 PM
coudamau
Jan 14, 2020 09:08 AM
Bettedaviseyes
Jun 19, 2014 08:16 PM
xFLUFFYxGUYx
Mar 22, 2012 11:48 AM
cma371
Oct 17, 2004 04:12 PM
