How to replace Transmission Solenoid Pack on a 1998 Galant SOHC
Old Jun 15, 2013 | 05:37 PM
rottenapple94's Avatar
Default How to replace Transmission Solenoid Pack on a 1998 Galant SOHC
can anyone offer a step by step tutorial on how to change out a tranmission solenoid pack on a 1998 mitsubishi galant 2.4 SOHC?
car overheated, check engine light came on (faultcode P1750) solenoid assembly
Wont go in reverse (acts neutral in reverse)
can be driven in drive but wont shift
do me a favor and let me know what size sockets Ill need and labor hours involved, as well as anything else you believe can be helpful, thanks in advance!
Old Jun 15, 2013 | 07:02 PM
You don't, you replace the transmission.
Old Jun 15, 2013 | 07:24 PM
thanks for the reply, I dont have time to pull a front wheel drive trans I just want to fix the issue that keeping the car off the road, any additional help appreciated thanks.
Old Jun 15, 2013 | 07:44 PM
Maybe you'll have better luck with yahoo answers.
Old Jun 16, 2013 | 01:53 PM
mxmikie's Avatar
I have put a test for the converter clutch solenoid.
http://www.2carpros.com/forum/automo..._Control_1.jpg
http://www.2carpros.com/forum/automo...ontrol_2_1.jpg
INSPECTION
1. Disconnect the Torque Converter Clutch (TCC) solenoid connector.
2. Measure the resistance between the TCC solenoid side connector terminal 2 and the body ground. Standard value: Approximately 13 ohms [at 20 °C (68 °F)]
3. If the resistance is outside the standard value, replace the solenoid valve assembly.
I have attached info for the shift solenoid…….use the first pic for the location.
http://www.2carpros.com/forum/automo..._Shift_1_1.jpg
SHIFT CONTROL SOLENOID VALVE A (SCSV-A) CHECK
1. Disconnect the SCSV-A connector.
2. Measure the resistance between the SCSV-A side connector terminal 3 and the body ground. Standard value: Approximately 22 ohms [at 20 °C (68 °F)]
http://www.2carpros.com/forum/automo..._Shift_2_1.jpg
SHIFT CONTROL SOLENOID VALVE B (SCSV-B) CHECK
1. Disconnect the SCSV-B connector.
2. Measure the resistance between the SCSV-B side connector terminal 4 and the body ground. Standard value: Approximately 22 ohms [at 20 °C (68 °F)]
Use the first pic, this is the test for the pressure solenoid.
http://www.2carpros.com/forum/automo...essure_1_1.jpg
INSPECTION
1. Disconnect the Pressure Control Solenoid Valve (PCSV) connector.
2. Measure the resistance between the PCSV side connector terminal 1 and the body ground. Standard value: Approximately 3 ohms [at 20 °C (68 °F)]
Old Jun 16, 2013 | 01:56 PM
mxmikie's Avatar
Shadowplane676
Jul 7, 2021 07:50 PM
alyster
Sep 20, 2013 11:42 PM
Hemihunter
Aug 10, 2011 05:52 PM
sickend
Nov 1, 2006 01:56 AM
Dreamer13
Jun 21, 2006 04:15 PM
