major idle drop after installing new air filter
Old Jul 31, 2011 | 10:53 PM
eyebidder's Avatar
Default major idle drop after installing new air filter
Got a problem....put in a new air fllter in my 3.8 engine '04 Galant and immediately noticed a drop in idle from around 1100 to 500rpm(at idle). If I switch on the AC it drops even farther almost to the point of dying....the AC even has these clicks heard every 5 seconds at this very low idle but when I increase the idle they go away. At a complete stop with AC I'm lucky to leave a stop light without the engine dying.
This all just started as soon as I put in a new filter. I don't think I hit or changed anything when installing the new air filter but I can't think of anything else that would cause the idle to be so low!
Any ideas would be appreciated!
Thanks!
Old Aug 1, 2011 | 03:17 PM
Navydude246's Avatar
did u mess with the mass airflow sensor
Old Aug 2, 2011 | 06:07 AM
eyebidder's Avatar
I had also disconnected the battery to clean the terminals so it turns out the computer had to re-learn the idle speed with AC on. Took about a day of driving with AC for it to get better.
Not sure where the mass air flow sensor is but the mechanic disconnected/reconnected the hose which I think went to the air flow sensor on the air duct going to the engine which sort of re-booted the computer so to speak.
Idle speed is only adjusted via electronically....no cables anymore! It's all about computers now.
monkeyman
Jan 22, 2013 06:36 PM
mvious
May 19, 2011 04:22 PM
jonerik26
Apr 20, 2010 11:31 PM
CCarl1
Mar 26, 2008 08:28 AM
