Oil on the spark plugs
Old Jun 26, 2005 | 06:43 PM
m168s's Avatar
Default Oil on the spark plugs
Just changed the spark plugs on my 2000 galant 2.4L three of the plugs had no visible oil on them but oil on the spark plug boots at the top and the third the one on the end of the driver side had oil all over it. Has anyone experienced this problem? solutions? Car is not consuming oil and no visible black smoke out of tail pipe. Any help would be appreciated..thanks
Old Jun 27, 2005 | 12:47 PM
pc's Avatar
pc
Default RE: Oil on the spark plugs
Appears to be simple valve cover gasket. Usually not a complicated job just labor intensive due to all the stuff that needs to be removed. You also may want to check the PCV valve connection to the valve cover and see if oil is puffing out there. Check you PCV for good operation.
theor23
Apr 17, 2014 02:39 PM
bassplar
Feb 16, 2014 12:52 PM
mitzubshi1
Apr 22, 2012 07:44 PM
760_3000GT
Aug 15, 2006 05:34 PM
JimmyB
Nov 30, 2005 07:03 PM
