Problem at low RPM's-2.4L Galant'03
Old Feb 27, 2006 | 10:22 PM
ilko100us@yahoo.com's Avatar
Default Problem at low RPM's-2.4L Galant'03
Hi,
I have experienced a problem at low RPM's - in taffics my engine oil lamp is getting on. It shutts off after RPM's are at appr. 750 per minute and higher.
I changed the air filter and the spark plugs. The engine oil is at the required level. The car has 69,000 miles on it.
Does anyone know what can be the reason for these low RPM's?
Thanks.
Old Feb 28, 2006 | 11:58 PM
GalantRacer06's Avatar
Default RE: Problem at low RPM's-2.4L Galant'03
Hmm you should try resetting your ECU and resetting it by unplugging your battery for about 30 minutes, that could help...just a suggestion.
Old Mar 2, 2006 | 06:32 PM
DryBear's Avatar
Does this only happen during traffic or any time the car is idling?
Check the intake manifold at the trottle body - the intake manifold on the I4 99-03 Galants have been known to crack at the area near the trottle body.
While you are at it, you might try cleaning your throttle body as well.
joe02184
May 25, 2011 06:44 PM
newguy99
Dec 30, 2010 09:01 AM
newguy99
Dec 21, 2010 10:41 AM
neurocrash
Apr 20, 2008 08:04 PM
mtalma
Dec 11, 2005 04:52 PM
