Push break-pedal, dash lights come on, why!
Old Dec 23, 2019 | 02:01 AM
MRDIY's Avatar
Question Push brake-pedal, dash lights come on, solved!
Hello forum
This issue is with a 96 Galant. When I press the brake pedal, the dash lights come on. without the key in the ignition, the lights come on and the warning tone sounds. some background on the car; it has been sitting for months, I had to change the expansion plugs. After all the work was done, this issue with the lights started. I am going to go through the wiring but if somebody knows what might be the problem, it would be great to cut time in this process down.
Update: I was checking the brake light bulbs that I recently put in and I found a single filament bulb in a socket that takes doubles, problem solved. Lesson to be learned, trust your gut, even if it seems to good to be true.
Ravenstormy
Oct 21, 2019 01:03 PM
Maximus99
Sep 16, 2017 07:23 PM
Bong061066
Feb 27, 2017 05:01 AM
98gstspy
Jul 2, 2008 12:10 PM
wicked2407
Oct 25, 2006 06:07 PM
