SPEAKERS
Old Feb 18, 2006 | 12:02 AM
MISCHIEVOUSLIBRA's Avatar
Default SPEAKERS
I HAVE A '00 GALANT AND RECENTLY PUT BACK IN MY FACTORY CD RADIO...MY SPEAKERS DOESN'T SOUND ALL TOO GOOD AND I WOULD LIKE ADVICE ON GETTING SOME NICE SPEAKERS FOR A CLEAR PREMIUM SOUND...ANY SUGGESTIONS???????
Old Feb 22, 2006 | 08:25 PM
mapid145's Avatar
Default RE: SPEAKERS
u want both front and rear ones... i got pioneers.. 160W 6 3/4 in the front and 300W 3way 6X9s in the back.. sounds nice but would defiently recommend getting a better head unit.. try to keep the brands the same cus it usually sounds better
Old Mar 22, 2006 | 10:41 PM
bleulemonade's Avatar
how do you remove the back deck, to replace the factory 6x9 speakers.
Old Apr 1, 2006 | 04:31 PM
UrDoneSRH's Avatar
ok first off, your speakers probably sound like *** due to the factory headunit, and if it has a factory amp and it was bypassed you might not be getting enough power to the speakers. otherwise as far as replacing speakers, always replace stock speakers because they are always cheap peices of crap. My favorite brands are JBL, Alpine & Pioneer... if you want to spend some $$$ go with the JBL power series. Keeping brands and speakers the same doesnt matter really other than for looks and bragging rights, you will almost never be able to tell the difference of brands. And removing the back deck.... there should be 3 BOLTS on the rear dash under the child restraint clips... if it doesnt come off after removing those try going into your truck and looking up at the underside, you may have to remove the brake light cover on the rear dash to get it up.. after that it should be 4 screws on each speaker. Good luck guys hope i could help
Old Apr 7, 2006 | 02:18 AM
MITSUBISHIMAN's Avatar
Hey,
We Have a wide range of JVC and KENWOOD Speakers that would do the trick very nicely,
But if you have just replaced it with your standard stereo they usually arnt all the best when it comes to watts and power output to your speakers. i would suggest an aftermarket stereo if you are looking for clear quality sound.
JVC are probably my choice of speaker theres affordable and are very reliable..
Thanks,
Lucas.
shamsulaswad
Mar 18, 2006 01:00 PM
Flipz
Aug 10, 2005 10:13 AM
crunchie
May 3, 2005 03:21 PM
aswahdan
Nov 12, 2004 10:25 AM
velcrobots
Nov 15, 2003 07:28 PM
