Suspension Problem
Old May 25, 2006 | 10:15 PM
tuss2oo5's Avatar
Default Suspension Problem
My car makes a terrible squeaking sound. I know the brakes may be part of the problem, but the springs look low on the passenger side of the car, and i get complaits from my bro that it feels funny when i hit bumps. Eventually i want to get everything replaced, i just want to know if i should do it as soon as i can, or if anything like this is normal. And how much it would cost to get my suspension fixed.
Old May 26, 2006 | 12:54 AM
Evil1993Eagle's Avatar
Default RE: Suspension Problem
Is the noise coming from the front or rear? How many miles are on the car? Sounds like a bad strut or something related to that.
Old May 27, 2006 | 06:10 PM
tuss2oo5's Avatar
The noise is coming from the front, and there is a little over 62,000 miles on it.
Old May 27, 2006 | 09:02 PM
It could be several things, struts, strut mounts, control arm bushings, ball joints, or tie rod ends.
Old Jun 9, 2006 | 10:31 PM
tuss2oo5's Avatar
Problem solved, It was my sway bar link (whatever that is) was rubbing againts the axel because it was bent. $80 later, problem solved, new sway bar. the end.
Old Jun 9, 2006 | 10:33 PM
i get a little creaking sound when i go over some bumps
Old Jun 12, 2006 | 01:50 PM
acitydweller's Avatar
glad it worked out for you. I may have this replaced as well.
natalie eclipse
Aug 25, 2009 05:22 PM
00_diaman
Jan 13, 2009 10:45 AM
4Geclipse
4th Generation
Feb 13, 2008 11:39 PM
miche77e
Oct 31, 2005 12:16 AM
enzo_hashmat2006
Aug 16, 2005 06:43 PM
