transmission trouble
Old Mar 3, 2008 | 09:49 AM
96 galant's Avatar
Default transmission trouble
96 galant is stuck in limp in mode has a p1750 code any suggestions
Old Mar 3, 2008 | 01:01 PM
4Grim's Avatar
Default RE: transmission trouble
That code isn't listed in the OBD II codes list here in the forums...can you re confirm thats the code?
I had a 95 Galant and when my transmission went into failsafe mode (stayed only on 3rd gear) it was because my TCU had failed.
Old Mar 4, 2008 | 10:16 PM
jgbrules's Avatar
hello! p1750 is a tranny code, but will show up in the MFI as a general code.you will have to get a scanner that will go into the trans data in the vehicle, there you should find more trans codes that will give you a better idea of whats going on. if you cant access the trans data, a message like cant communicate. the TCU could be bad like 4grim said. keep us posted! greg...
beetlenut
Jan 22, 2017 06:11 AM
Lp2236
Jun 10, 2010 03:13 PM
lovinmrv
Jan 10, 2009 02:59 PM
mrobison
Jul 5, 2007 03:36 PM
