Water Pump replacement
Old Aug 3, 2006 | 12:36 AM
amit_ahuja83's Avatar
Default Water Pump replacement
The plate on top of the water pump that screws into the pulley is broken and stuck into the pulley. I need to replace the water pump. How hard is it? Can I do it myself.
Old Aug 3, 2006 | 03:51 AM
Joel_CA's Avatar
Default RE: Water Pump replacement
To replace the water pump, you'll need to remove the Timing Belt. Not too difficult of a job depending on your skill level. Based on your prior questions regarding the waterpump drive belt- i suggest you have the job done by someone more qualified.
Joel, CA
Old Aug 3, 2006 | 04:10 AM
Can it not be done without removing the timing belt??
Is there a place where I can find a free repair manual??
mlduncan96
Jan 14, 2015 03:40 PM
mcgyverit
Dec 4, 2012 09:07 PM
JohnnyK
Jun 2, 2011 01:10 PM
*master
Mar 4, 2005 11:33 PM
Knaackers
Jan 14, 2005 02:54 AM
