02 lancer es no start, need help
Old May 15, 2009 | 08:50 PM
aznboi_2's Avatar
Default 02 lancer es no start, need help
02 es turbo lancer 5spd
the car was mine friends car, he attempted a diy first time timing belt change. Yes he fuked it up. the pistons slapped the valves and bent the valves. Before i pulled the motor out. I found out the pump was not turning on and it did not have spark at all.
I traded my honda civic for his car so now i have it.
I bought a new motor for it. The motor is from an automatic dont know if the ckp and the rest of the sensors are the same but they all plugged right up. So Yea i dropped in a new motor. The only thing i swap from the spd was the coil and plugs, spark plugs, tapped oil pan and intake manifold, injectors too. Before each spark plug wire the previous owner wired in a resistor. Still no fuel or spark.
What i tested so far
-jumped fuel pump it turns on
-tested power wire going to fuel pump w/key on the on position, no power is being found.
-jumped fuel pump relay it turns on, and tested good w/multimeter
-chk for spark no spark
-car cranks very fast as in normal, not slow
Old May 17, 2009 | 05:58 PM
aznboi_2's Avatar
i read up on some forums, i checked my ckp (crankshaftpositionsensor) i used a multimeter and getting 0.07-0.08 volts while cranking. The ckp also sends signals to the ecu to fuel pump on to send fuel to the injectors. So if im not getting spark or fuel and the ckp checked out ok, should i go buy a new ecu?
Old Jun 5, 2009 | 10:57 AM
jorginho10br's Avatar
the A/T ecu is differently tuned than the M/T. the CKP sensor should be the same. on start up, A/T have to re learn idle..which is characteristic of the ecu, the safety neutral switch might be faulty tho, if u put a M/T on it...u are deff gona have a no spark no fuel problem.
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
RigilKent
Feb 11, 2010 08:22 PM
Ithian
Jan 31, 2008 10:21 PM
cougarkid
Aug 22, 2007 01:11 PM
