02 Lancer OZ Jerking Engine
Old Oct 21, 2008 | 05:11 PM
mitsupartsman.com's Avatar
Default RE: 02 Lancer OZ Jerking Engine
My thought was not that you can't drive a stick. I was wondering if you would recognize clutch chatter if you felt it. If the person you bought the car from was hard on the clutch he may have
damaged the flywheel and now it dosen't engage smoothly when its warm.
Good luck to you. I hope he finds your trouble
Old Oct 23, 2008 | 04:41 PM
pwitoslaw's Avatar
The clutch is engaging smoothly its jerking when the car is in the gear i also suspect clutch disk slowly coming to the end of it life because when i go uphill the clutch slips on the second gear but this only happens occasionally. Yesterday i went to another mechanic and they said that the jerking is normal, but i still doubt they are right.
Old Oct 23, 2008 | 05:14 PM
Did you ask them to look at the engine mounts? they may not be broken but they may be very weak and loosen up when it the car warms up.
Old Oct 24, 2008 | 06:56 PM
pwitoslaw's Avatar
i just got my tranny fluid changed, and about the mounts You were right. Both front and the back motor mounts need to be replaced, once i replace them ill post the replay on how it worked out. One more thing is it normal for the mounts to brake so fast the car is only 60K ?
Old Nov 8, 2008 | 10:40 AM
pwitoslaw's Avatar
Just wanted to post the update about the mounts. The front and rear mount was replaced yesterday, The car doesn't jerk or shatter anymore like before problem fixed thanks for you help.
Old Nov 14, 2008 | 08:58 PM
Symyon's Avatar
God...I could swear that your problem are the Front and Rear mounts, but you said you went to mechanics and they said that's normal... .
I had problems with mounts on my Eclipse 1998... last week replaced them on my Lancer...... so sorry couldn't help you before.... .
mari_cf39
Jan 5, 2012 12:26 AM
Shifty92
Aug 14, 2009 05:52 PM
kuli
Mar 22, 2009 12:28 PM
pwitoslaw
Feb 10, 2009 02:19 PM
joeski
Aug 27, 2004 11:29 AM
