04 R/A Lancer Holding back at 4K!!
Old Jan 20, 2007 | 03:37 PM
MiamiRalliart's Avatar
Default 04 R/A Lancer Holding back at 4K!!
I'm having a bit of trouble with my 04 R/A lancer. Seems that in every gear when the rpms reach at about between 4-5k its seems to lose power or holding back. Any clues as to what this could be?
Old Jan 20, 2007 | 04:05 PM
Marty Ro's Avatar
Default RE: 04 R/A Lancer Holding back at 4K!!
Catalytic convertor?
Old Jan 21, 2007 | 11:29 AM
i was thinking maybe it could be the MIVEC system that's failing, MAF sensor, or maybe bad plugs. anyone else have a suggestions or have had this problem occur before?
Old Jan 22, 2007 | 05:18 PM
RMUDBUGS's Avatar
Take it to the dealer.
Old Jan 23, 2007 | 04:53 AM
blackdiamond's Avatar
maybe its a mitsubishi??
Old Jan 25, 2007 | 06:53 PM
Marty Ro's Avatar
All the things you have listed are to blame if the engine has a malfunction all the way from 800 to 7000 RPM. If the catalytic convertor is clogged, you won't have the same flow on exhaust so the engine gradually cuts the amount of gasoline injected into the cylinders.
Now tell me how the car reacts:
- at 4000 RPM the injection cuts as the maximum RPM is reached
or
- you gradually lose power at about 4000 RPM ?
If the first behaviour occures, it's an electonic matter and you have to go to the shop. If the second behaviour occures, you can check the temperature on central tunnel, around shifter or you can look under the car to see the cat. If it's clogged, the temperature around the shifter (inside the car) is pretty high and/or the cat almost turns to red.
UNDER ANY CIRCUMSTANCES, DON'T ATTEMPT TO CHECK CAT'S TEMPERATURE WITH YOUR HAND!!!
Old Jan 26, 2007 | 10:12 AM
The first thing you mentioned happens. It seems like after 4000 RPM between there and 5000 RPM the injection cuts off. i cannot Accl. unless i switch gears. Now this does not happen all the time but it does happen often. I was thinking maybe it could be the MAF sensor?
Old Jan 26, 2007 | 11:46 AM
Marty Ro's Avatar
Could be the MAF or God knows which other sensor, could be the fuel pump, could be an electric fault. Anyway, take it to the dealer and run a computerised test.
shutterbugs
May 28, 2012 07:42 PM
kjvildal
Apr 5, 2009 12:30 AM
Silvertooth
Mar 16, 2007 04:42 PM
EMonz57
Jul 3, 2006 11:41 AM
jdmeclipse92
Oct 29, 2004 12:58 AM
